tysn Posted June 22, 2005 Share Posted June 22, 2005 i just changed my plugs and wires on my xt turbo, now it idles a little rough. any thoughts on why is it doing this? Quote Link to comment Share on other sites More sharing options...
tysn Posted June 23, 2005 Author Share Posted June 23, 2005 anyone? Quote Link to comment Share on other sites More sharing options...
richierich Posted June 23, 2005 Share Posted June 23, 2005 1) You got a plug cross threaded. 2) You did not get a plug wire properly snapped to the plug. 3) You did not check to make sure the plug wires that fit on the distributor cap were inserted correctly into the cap (may not have enough of the end showing to make good contact. 4) You installed the spark plug wires on the cap in the wrong order. 5) You messed with the timing 6) You had the problem before you did the tune-up and you need other tune-up related items because wires and spark plug did not fix your problem. I am going with #3, but I have seen them all. Good Luck tell us what you find. Quote Link to comment Share on other sites More sharing options...
