June 25, 200520 yr Strange, Any Ideas? Here's the situation: I just replaced both axles on the 82 at the same time. I went to test drive it and it won't move!!! What the hell? First time iv'e ever had that problem. How could the tranny bind? Any thoughts? Signed stuck in misery. :-( Kurt
June 25, 200520 yr does it feel like it's in gear and trying or just not doing anything? manual or automatic? automatic im guessing and FWD? if you violently yanked on the axles while removing maybe one or both of the stubs in the transmission (that the axles slide onto) came out of place? doubtful, but weird problems lend themselves to wierd situations.
June 25, 200520 yr Author ok. both axles are spinning freely BUT NOT IN OPPOSITE of the other. Meaning while jacked up, spinning one tire, the other does not turn in the other direction... Ebrake cables are properly installed. no noise.
June 25, 200520 yr its not in "false neutral " is it. i cnanged an axle and the car wouldnt go, i was about thetear into the clutch until i realized i was parked on an embankement, looked underneath and it bum ped the fwd lever between hi and lo
June 25, 200520 yr Author Ok. frozen brake piston. Somehow the left side seized during reassembly... I screwed it in one half turn and reset it. runs fine now. Thanks for your ideas. BTW, Shawn, Miles gonna make it to Midwest?
