June 29, 200520 yr So i have a line on a 99RS Motor with a blown head gasket... It's a block, with intake manifold, water pump, oil pump, coolant passage, some other misc stuff. Only 100 bucks. thinking of throwing it in the ice racer...and having 165 hp without even trying...then maybe running a turbo and making 4 psi of boost.... should go like stink...and have piles of torque. Seems like it's a no brainer for 100 bucks (CDN btw)
June 29, 200520 yr dude jump on it, just use the newer style head gaskets and throw on some EJ22 heads. 11:1 CR!!!! ~Josh~
June 29, 200520 yr Author so just dump on the Ej22 heads and i'll have 11:1 compression...hmmm...figure with that compression, a header, open exhaust, intake, and Megasquirt you could probably be at what? 180hp?
June 29, 200520 yr well dont take my word for it, do some research first, i might be talking out my A$$. ~Josh~
July 1, 200520 yr i am currently in the process of building the 2.5 block with the 2.2 heads, so let me know if you get done first..... ya know how everything worked out....
