loyalewithcheese Posted July 1, 2005 Share Posted July 1, 2005 hey all, just picked up a loyale and wanted to get some of it's quirks fixed. currently the driver side power window controls can roll down the rears, but can't roll them up. however the rear switches can roll up the rear windows. the drivers window works fine, but nothing can roll down the passenger window. i'm fairly decent with electrical systems having customized motorcycles and fixed aging vws, but neither of those had power windows, so i'm a bit lost as to where to start. is there a central relay for the windows that could be faulty? or is it probably a fault at the switches? anyone got an working components they think will help this issues? or any test to try to help figure out wtf is going on? tia droo Quote Link to comment Share on other sites More sharing options...
muellerdeal Posted July 1, 2005 Share Posted July 1, 2005 i dont if there are relays are not but it takes like 5 minutes to take off the door panel and clean the connections my motor went out on my passangerside on my 86 wagon matt Quote Link to comment Share on other sites More sharing options...
Cougar Posted July 1, 2005 Share Posted July 1, 2005 There is a common relay for all the windows. I would check the passenger side motor and the wires to it through the door for a problem. The other problem sounds like a dirty switch or broken wire to the switch at the location of the switch that is not working. Quote Link to comment Share on other sites More sharing options...
loyalewithcheese Posted July 1, 2005 Author Share Posted July 1, 2005 There is a common relay for all the windows. I would check the passenger side motor and the wires to it through the door for a problem. The other problem sounds like a dirty switch or broken wire to the switch at the location of the switch that is not working. thanks guys that makes sense. does anyone happen to know if the motor is used in any other models? or should i just pull it out and go to the junkyard and look an any japanese car? thanks droo Quote Link to comment Share on other sites More sharing options...
azsubaru Posted July 1, 2005 Share Posted July 1, 2005 The window switches on my Loyale get dirty and quit working about once a year. Cleaning them isn't difficult and is worth trying first. After you get the switch out, make sure you've got a good clean spot to work before you take it apart - small pieces can disappear quickly, especially the multi-switch from the driver's door. I use electronic spray cleaner and a pencil eraser to clean the contacts. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 1, 2005 Share Posted July 1, 2005 my car does the same thing, the master switch will roll down the back windows but not up. the rears are fine with the rear switches. i suspect my master switch needs cleaned replaced as far as the way the system works, if any of the switches are unplugged from their harness none of the windows will work Quote Link to comment Share on other sites More sharing options...
loyalewithcheese Posted July 1, 2005 Author Share Posted July 1, 2005 as far as the way the system works, if any of the switches are unplugged from their harness none of the windows will work cool, thanks for the tips, i will try cleaning it out and see what happens. btw, love the trashwagon(s) cheers droo Quote Link to comment Share on other sites More sharing options...
SakoTGrimes Posted July 1, 2005 Share Posted July 1, 2005 I should have just got off my butt and done it. I was going to throw slices of 'Merican cheese all over my Loyale and post a picture of it here. Anybody get it? I guess it's too late now. Quote Link to comment Share on other sites More sharing options...
