Brumby Boy Posted July 14, 2005 Share Posted July 14, 2005 Hay if i get a hold of an EA82T, will it bolt straight in other than the running of the wiring?? If not would it still be easer to do than the EJ20T swap? Thanks for all the help Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted July 14, 2005 Share Posted July 14, 2005 Hay if i get a hold of an EA82T, will it bolt straight in other than the running of the wiring?? If not would it still be easer to do than the EJ20T swap? Thanks for all the help Well either one will pretty much bolt up, the EJ20G (not T) will require a bit more fabrication (rear tranny mount), both will require some re-wiring, the EJ probably more then the EA. But if you are looking for power AND reliability, the EJ20G is the only way to go. Quote Link to comment Share on other sites More sharing options...
Brumby Boy Posted July 16, 2005 Author Share Posted July 16, 2005 What do you mean EJ20G? What about the EJ25? Here in oz we dont seem to have the HG problems with the 25's that the people over seas seem to be havin. Quote Link to comment Share on other sites More sharing options...
