Will it fit?
Hay if i get a hold of an EA82T, will it bolt straight in other than the running of the wiring?? If not would it still be easer to do than the EJ20T swap?
Thanks for all the help
Well either one will pretty much bolt up, the EJ20G (not T) will require a bit more fabrication (rear tranny mount), both will require some re-wiring, the EJ probably more then the EA. But if you are looking for power AND reliability, the EJ20G is the only way to go.
