EA82 and EA82-T Lash Adjustor Difference??
What??? Like you mean hydraulic lifters?? if thats what you mean... no. There are 2 different styles that I have seen over the years of ea82's, but they are interchangeable
what he said.
there are caps that looked a tad different, but same specs and are interchangeable. and the caps aren't model dependent....maybe just changed with time or supplier or something. same part though.
The Hydraulic Lash adjuster. Thats what i was told it was... the thing the rocker arm sits on and that holds it there under the cam... the thing that gives the rocker arm pressure so it doesnt just fall off...
...the thing that when it breaks, it makes your car run like poop. ...
i'll order one for my EA82T even though the spec says EA82.
thanks!!
