July 22, 200520 yr I got an 84 FWD GL Wagon 1800 OHV and I need to adjust the clutch properly. I see that in the book it calls for 10-20MM of free play in the cable. So does this mean 10-20MM before it starts to move the clutch lever, or does it mean 10-20MM of complete freeplay before the cable begins to get taut?
July 22, 200520 yr Good luck! My Haynes and Chiltons say different things and niether really make much sense.
July 23, 200520 yr I gave up with book numbers too, for cable. I ended up leaving clutch seemingly, hardly disengaging, to assure myself of true seat.Its feel will change going through seasons where I live (extreme) .bizarre quirk....
July 23, 200520 yr make all clutch adjustments before the hill holdr adjustment. majke sure the hill holder is not too tight to begin with anyway. i tighten the nut by hand till it takes the slop out of the fork. then a turn or 2 to set my pedal where its comfortable you want your pedal to engage right off the floor, not way up at the dash
