August 10, 200520 yr I have not had this car for long. It is the twin scroll turbo version. The problem is that sometimes the engine management light comes on and at the same time the dccd switches from auto to another mode where it turns on a green flashing light and that constantly flashes. At the same time the car loses power and if you press the accelerator it spits and just does not want to move. Its like the diff is locked. The car has no mods other than a down pipe and full exhaust (no cats). thanks.
August 10, 200520 yr its prolly got something to do with the fact that the cats are gone...... youre o2 sensors are probably freakin out and throwing the check engine light, which then causes limp mode ( full rich ) then making the car not want to do anything. not positive, just my .02 cents
August 10, 200520 yr its prolly got something to do with the fact that the cats are gone...... youre o2 sensors are probably freakin out and throwing the check engine light, which then causes limp mode ( full rich ) then making the car not want to do anything. not positive, just my .02 cents I agree with his thoughts.
August 10, 200520 yr Author its prolly got something to do with the fact that the cats are gone...... youre o2 sensors are probably freakin out and throwing the check engine light, which then causes limp mode ( full rich ) then making the car not want to do anything. not positive, just my .02 cents thanks for the help. please can you tell me which is the air flow sensor as this car has two one is at the turbo end and one at the other end of the down pipe both are connected.
