bella Posted August 15, 2005 Share Posted August 15, 2005 I heard that my noise(only on the left side on bad roads) can be resolved from an adjuster that my steering box have. Anyone now about this...? :banghead: Quote Link to comment Share on other sites More sharing options...
bella Posted August 16, 2005 Author Share Posted August 16, 2005 Anyone now about this adjustment of steering box...?????? Quote Link to comment Share on other sites More sharing options...
Humble Nuto 53 Posted August 16, 2005 Share Posted August 16, 2005 there is an adjustment for the lash between the rack and the pinion. on the bottom of the rack is a nut and lock nut. its only good for so much, you dont want to have it so tight that it binds the steering. usually rattle is caused by the bushings in the end of the rack housing showing wear. a rebuilt rack with new inner tie rods is the cure... ive seen them priced between 160.00 and 200.00. havent located the parts to DIY yet, but havent called dealer. i would install a rebuilt before i spent much on doing it myself. Quote Link to comment Share on other sites More sharing options...
bella Posted August 16, 2005 Author Share Posted August 16, 2005 Any details about how much(any clue) should I adjust the nut and in what sense?? Thank you. Quote Link to comment Share on other sites More sharing options...
Humble Nuto 53 Posted August 16, 2005 Share Posted August 16, 2005 only good for so much, you dont want to have it so tight that it binds the steering. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted August 16, 2005 Share Posted August 16, 2005 the noiise is probably the ball joint, not the steering Quote Link to comment Share on other sites More sharing options...
bella Posted August 16, 2005 Author Share Posted August 16, 2005 The ball joint is ok....:-\ Quote Link to comment Share on other sites More sharing options...
