transaxle seal question
To all those who would venture an opinion,
I think I have a leak from the driveshaft end of the transaxle (2nd Gen Brat, EA81 manual trans/ 4WD). My question is simply, is this an easy fix? Can I drop the driveshaft and get at the bad seal to replace it or will it require any special tools, tricks or new Four Letter Words?
Thanks,
Brian
Thanks,
Brian
yes, you should be able to get it out after removing the driveshaft.
  • 8 years later...
and how is that done?  exactly? I don't see snap rings on the outside of my u joints?  ... unbolt rear drive shaft at the rear dif. slide the slip yoke out. if you just need to replace the seal, no need to drop the exhaust.
Edited by filthytactics
to clarify, you mean the rear driveshaft and not the CV shafts right?  "driveshaft" is often used for both.
Make sure the leak is not from the shift rod.  They leak alot on 4spds.
As filthy said...
Unbolt the driveshaft at the rear diff, then slide the driveshaft off the slip yoke.
The seal is right there.
Might want to grab a drip pan.  You will probably loose a bit of fluid.
