spider intake swap
hey all i searched the USRM for this but I couldn't find anything about...maybe I'm too impatient. OK
I was thinking about putting a spider intake on my GL-10 turbo. I was wondering about what I would need. All the parts and such. Thanks.
currently doing just this...... found a standard turbo intake wiring harness off an 88-87 in a mich. J/Y. Now I am going to splice/butt-connect the spare gl-10 intake i currently had on the shelf with this J/Y intake harness and then plug it inline between the XT turbo (87.5? right) connectors and the GL-10 connectors under the coil. Blunt terms it'll be an extention cord!.
Removed all tape and plastic covering.
layed them both out flat
and seperated the oil and water yellow lines;
the knock,EGR and throttle body connectors;
make sure the wires are ALL ACCOUNTED FOR!
then I'll cut off the plugs and add in the needed wire extensions to balance it all out evenly.
install the engine blah,blah,blah,blah...
tedious but, patience is necessary.
