amajeff99 Posted August 18, 2005 Share Posted August 18, 2005 two days ago my 1997 impreza outback sport started having a high idle problem, after it is started and it warmes up the idle will not drop below 1200 rmp. the check engin light is not on and a code reader shows pass. I do not think it is a vacume leak and other than the high idle it is running smooth. i disconnected the negitave terminal for a to reset the computer and it fixed the problem for about 10 min. HELP. Quote Link to comment Share on other sites More sharing options...
macdonaldks Posted August 18, 2005 Share Posted August 18, 2005 I had a similar problem with my 2.5. It turned out that my IAC was sticking and causing my high idle condition. Rather that remove and clean the IAC. (It's a bit of work). I sprayed carb cleaner through an intake hose that ran to the valve. Valve now moves freely and the idle problem has been cured. Regards; Ken Quote Link to comment Share on other sites More sharing options...
amajeff99 Posted August 18, 2005 Author Share Posted August 18, 2005 thanks i will give it a try. where should i look for the IAC valve so i can spray carb cleaner in it. Quote Link to comment Share on other sites More sharing options...
Olnick Posted August 18, 2005 Share Posted August 18, 2005 Right under the throttle body, can be seen from the passenger's side. Do a search here on the forum--there's lots of info. Quote Link to comment Share on other sites More sharing options...
