help requested:WA or OR
Traveler in WA state. Needs backyard repair space. Timing-belt overdue & radiator leaking. Have parts and car is running . Require off street location to fix up 91 Legacy. Canu relate your t-belt experiences w/2.2? A couple of hours?
wich part of the state are you in?
since your traveling
Iam in anacortes today. checking in at local library computer. Jim Dawson
well if you want to dive into the timing belt with me as i do my car you can, it will be my first, although i am mechanically inclined. i live by everett.
if you make it down around longview,wa i can do them as well and have done a few
Thank you for your offer. I'll check in with you again via this board.
Thank-you for the offer. I'll be on-line again to keep in touch. Jim D
You may already know this but replace the lower rad hose along with the rad.It's cheap insurance and easy to replace with the rad.The rad job is about 2-3 hours and quite simple.
Good luck on the timing belt.
