EJ22 fixing....
Hello all,
Had a little meet with oddcomp today and we looked over my engine. We agreed that perhaps only the rod bearings are hosed and that the power loss in the engine is the knock sensor retarding the timing......
So im asking you gurus who tear into engines...is this theory plausible?? and if i unbolt the Oilpan, will i be able to get to the bearings and rods??
THanks for the help
Cory
For more info check out the initail post http://www.ultimatesubaru.org/forum/showthread.php?t=41825
Hello all,
It's definately plausible, the knock sensor signal can prod the ECU to yank 10 or more degrees of timing. That's gonna knock the wind out of the midrange torque and give you molasses-like throttle response.
Have you done a compression check?
Also what is the cause of the screech noise?
I'm not certain about refreshing the bottom-end ...from the bottom-end.
Well the screeching noise was only present for about 2 minutes when we first started the engine...now it just has a nasty rod knock...it idles fine but the midrange is gone......
Any other confirmations
Hello all,
THanks for the help
Cory
I've had a couple of EJ22s apart before and there's just no room to get a wrench onto the rod cap bolts; let alone a torque wrench when it time to reassemble. I know the shop I use to work at has a few used EJ22 longblocks on the shelf, maybe a shortblock too. The name of the place it Mt. Tech, their number is 503-650-3686, and their open Tuesday to Saturday 8 to 5
eh i was not totally sure i figured since it was a bigger motor there might have been room to do it
