August 28, 200520 yr Does anyone have the wheel alignment specs for a 91 legacy wagon. I just need to know how much toe is on the front and rear. Thanks.
August 28, 200520 yr Zero! At least for AWD models. If you're in a FWD, I think you need a tiny amound of rear toe-in. Camber is 0.0 front, but adjusting it to 0.25 will improve your handling massively. Rear camber is -1.0, but it's not adjustable.
August 28, 200520 yr The Australian Liberty has 0+/-3mm toe front and rear.(25.4mm=1 inch) I believe your legacy is identical to our liberty, they were 2.2 litre engines.
August 28, 200520 yr alignment specs are kind of subjective. I run zero toe front and rear, and -1.0 degree of camber front and rear. I'd consider that a "performance" alignment though. The shop you take it to should have all the info, personally, I'd run a little bit of camber front and rear and close to 0 toe
