August 28, 200520 yr I wish I could tell you... Even though I own one from the first shipment from Japan, I can't find any production date. I can tell you that I picked mine up in May of '03 and it probably takes a month on the boats to get them here so if I was going to guess mine was built in March, but that's a guess. Keith
August 29, 200520 yr Author late in 2002 = first production date for the USDM STi's jamie What do you mean by "USDM"? Is "late 2002" a good guess or some real info? What is the source of the info?
August 29, 200520 yr What do you mean by "USDM"? Is "late 2002" a good guess or some real info? What is the source of the info? United States Domestic Market.
August 29, 200520 yr What do you mean by "USDM"? Is "late 2002" a good guess or some real info? What is the source of the info? you must be new welcome. i work for subaru i dont tend to make random guesses earliest listing for replacment parts for STi begins with STi production date 10/2002 this would mean the first STi's off of the production line would have been stamped 10/2002 have other questions. let me know. have fun Jamie
August 29, 200520 yr I wish I could tell you... Even though I own one from the first shipment from Japan, I can't find any production date. I can tell you that I picked mine up in May of '03 and it probably takes a month on the boats to get them here so if I was going to guess mine was built in March, but that's a guess. Keith also... i must point out that the production date of your vehicle is stamped into it. open your drivers side front door. back of the door sill.. there's a plate there with the production date stamped into it. then you will know for sure when your car was produced. Jamie
August 29, 200520 yr also...i must point out that the production date of your vehicle is stamped into it. open your drivers side front door. back of the door sill.. there's a plate there with the production date stamped into it. then you will know for sure when your car was produced. Jamie When I get home I'll take a third look. I looked at both the plate on the door and the B pillar since that is where it is supposed to be. I didn't see it, but that deosn't mean I didn't miss it.
