axgutt Posted September 9, 2005 Share Posted September 9, 2005 I have a '95 Legacy L wagon, AWD, 5-speed with 241,000 miles. I just had another 60,000 mile service performed which included replacing the differential/transmission fluid. When I bought the car a couple of years ago (with 175,000 miles), the shifter was really loose. It shifts just fine, but there was a ton of play. A mechanic who checked it out at the time said that it was probably just missing a bushing. Anyway, it's worked just fine so I haven't messed with it. Well, now it seems to be a bit looser. For example, when I put it in 5th, the shifter goes all the way to the right of the opening. Also, I'll get a little bit of rattling from the shifter when I'm cruising in 4th. It's not jumping out of gear or anything, and the shifting action is still smooth. At first I thought it could be the new fluid, but I wouldn't expect it to make that much of a difference. Any ideas? Thanks Adam Quote Link to comment Share on other sites More sharing options...
SubaruLegacy2003 Posted September 9, 2005 Share Posted September 9, 2005 Most definately sounds like bushing, time to get a FSM and dig in..... Quote Link to comment Share on other sites More sharing options...
kevinsUBARU Posted September 9, 2005 Share Posted September 9, 2005 You will definately find this thread of interest...it sounds exactly like your problem, and it describes how to fix it. Good luck Kevin Quote Link to comment Share on other sites More sharing options...
BigMattyD Posted September 9, 2005 Share Posted September 9, 2005 Definitely check out the thread listed in the previous reply. I posted some of the pics I took when I repaired my shifter on my website. The address is listed within the thread. If you have specific questions, let me know. I just did it a month or two ago. Matt Quote Link to comment Share on other sites More sharing options...
