September 13, 200520 yr carbed, SPFI, MPFI....are all EA82 block oil pumps identical and require the same seals/o-rings for a oil pump reseal? got a carbed block with turbo heads on it and want to make sure the oil pump parts are the same.
September 13, 200520 yr I believe it was 1990 that they went to a larger shaft on the oil pump. Those pumps SHOULD fit into the old blocks just fine as I don't think they changed the block itself. Aside from that, there should be no differences.
