September 27, 200520 yr Turn signals and hazards stopped working on my Forester 2000. They began acting up in a delayed matter and now after you turn them on they might take 3 to 4 min. to work, and then turn off. Fuses are fine. I did some research and it might be the "turn signals and hazard module". Any body knows where it is located? Any other suggestions
September 27, 200520 yr There could be a relay box under the bonnet somewhere. Pop the lid off and there should be a diagram on the underside of it. Or perhaps in the fuse box in the drivers footwell? Actually, it does sound like you may have a bad ground connection somewhere.
September 27, 200520 yr Its one of the mystery black boxes by the hood release if I remeber right nipper
