idosubaru Posted September 29, 2005 Share Posted September 29, 2005 for the 2.5 to 2.2 liter swap i need a dual port 2.2 that was only available in 1995 right? is there anyway to look at the motor in the car to tell if it's dual port? does the exhaust manifold give it away? any pictures available? there's a couple available locally but i'm not sure what year or dual/single port. can a single port 2.2l swapin place of a 2.5 if i do some welding of the exhaust? Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted September 29, 2005 Share Posted September 29, 2005 i believe that the dual port was 90-94, but i could be wrong. if you look at the exhaust manifold, you should be able to determine if it is single or dual.... i do know that my 90 legacy has dual ports....... im sure you could use a single port, but if you do, you would need the exhaust manifold to go with it...... should just bolt right up. Link to comment Share on other sites More sharing options...
blitz Posted September 29, 2005 Share Posted September 29, 2005 Gary, in the event that you can't find a factory manifold in good shape, Borla makes a stainless header for the single-port 2.2 Link to comment Share on other sites More sharing options...
