92 Legacy Clutch HELP!!
When I stepped on the clutch pedal today, I heard a loud SNAP, and now the pedal is down and wont come back up????
It sounded like some cable broke.
Any Ideas????
John
Replace cable-seriously, I think you have diagnosed it correctly
That seriously sounds like the clutch cable broke. To double check, look on top of the transmission, just to the left (driver's side) of center. You will find an arm with two cables attached to it. The top one is the clutch acuating cable (the one you suspect is broken), and the bottom is the hillholder cable. If the top cable is loose enough to pull more than a quarter inch out, then you have the problem in your hands. . .
