October 13, 200520 yr Possible Pcv valve... I don't know... I'm pretty sure its not coolant... I'm not seeing bubles when running...
October 13, 200520 yr Its kinda hard to tell but is it BLUE or WHITE??? White is water/coolant, Blue is Oil.
October 13, 200520 yr Author white but its not like Water/coolent that has a sweet smell.. this has a nasty smell..
October 13, 200520 yr do you know when the last it was started? and if the fuel sat in it for a long time you could have some issues there.
October 13, 200520 yr Author it seems to run fine. but the Smoke starts coming out when I put it in gear, so I'm thinking its ATF burning off.. bad Modulator or something like that... and it keeps coming out for some time... since the trannies shot anyway...
October 13, 200520 yr I dont think there is any possible way for ATF to get into the engine and burn off. I would check every vac. hose and ever coolant hose and just make sure they are all hooked up right, i mean i've seen coolant hoses hooked to intakes and fuel return hooked to coolant and vice versa. I would just go over all the hoses under the hood and make sure they are all where they need to be.
October 14, 200520 yr Tranny fluid can get sucked into the engine through the vacuum line from the modulator, if the modulator diaphram is ruptured.
October 14, 200520 yr Good to know, i think the only other car that had somthing like that was the old fords...but anyway.....yeah.....i feel stupid.......
