4wd is on when front is elevated? - Stuck In 4wd
Hey,
Ive got another quetion. MY brat says the $wd is on when it is on a hill, it also begins shuttering in idle. Also when on a hill the tranny will not shift. If is like it binds up for some reason? Any ideas on how to fix this? Thank you everyone for all your help!
Thanks,
Ryan
NEW:
It will not come out of 4wd now, not at all, we have tried adjusting the linkage, pulling off the linkage...everything. You think it is the transmission mounts? Ill change them out i guess! Thanks!
Sounds like your transmission mounts may be bad and it's causing an awkward angle when you are on a hill. the 4wd light coming on has to do with a sensor in the center consol beneath the 4wd shift lever i believe. .. probably just needs a little adjustment... or you can just learn to ignore it :brow:
