October 17, 200520 yr I was installing a new clock and crossed red and black lead from clock. NOT A GOOD THING. I checked all the fuses under the dash. All good. Will crank. No horn ,radio, dome light. Any sugestions? JEFF
October 17, 200520 yr IIRC the ECU is on the same fuse as the Horn is. Like bobby said, check the fusable links. They're in a black case mounted on the coolant overflow bin under the hood.
October 17, 200520 yr Nice try but you aint gonna break a Subaru THAT easy Check fusible links; infact just replace them. Replace the fuse for horn/radio also. I've had fuses with hairline cracks I couldnt see but were still broke.
October 17, 200520 yr Author I was installing a new clock and crossed red and black lead from clock. NOT A GOOD THING. I checked all the fuses under the dash. All good. Will crank. No horn ,radio, dome light. Any sugestions? JEFF Cougar was correct Fuse#5. THANK YOU!
