September 28, 200322 yr i just pulled most of the wiring out of a 87 xt, with the flapper style maf. i am planning on sticking it into a carb car, and i was wondering where i might find some sort of diagram of just the wires i need to make the engine work. when i say most of the wiring, i mean i left the cab part there, but im thinking i might need the whole thing, even if i dont use all the cab controll stuff... anyone with experience, get me started?
September 28, 200322 yr I have a FSM for this turbo FI system, I could scan the ECU wiring and email it to you if that would help? You will need the ECU from under the rear parcel shelf.
September 28, 200322 yr Author this one isnt a turbo, but i bet most of the wires are the same. i do plan on boosting it after it runs. i did get the computer, took a while to figure out the comp was in the trunk. send it on over, thanks
September 28, 200322 yr sure thing, will have to drag out the scanner (I work on a laptop), you mind telling me where to send it? As far as I know the profile email doesn't let me attach files.
September 28, 200322 yr Author i found a diagram that helps alot... but only for the ej22 for vw vans and stuff.
September 30, 200322 yr Author anybody else got anything? like one i can buy and plug in and supply a power and ground and go? i can always wish right?
October 1, 200322 yr Originally posted by archemitis . . . and i was wondering where i might find some sort of diagram of just the wires i need to make the engine work. Did you receive my email last night?
