November 4, 200520 yr i am getting the 88 3door ready for winter and i found out that the rear wheel bearing is bad,can i get some information on how to replace it?????i have not done one on a subaru.i do have a 87 sub for parts and the wheel bearings are okay,how can i get to use them if the are the same anyways.thanks Bill.
November 4, 200520 yr you may need a pin wrench socket , if you look i asked about a place to get one
November 4, 200520 yr you may need a pin wrench socket , if you look i asked about a place to get one I consider the pin wrench socket an extravence and frivolity. A stout brass punch or drift works fine for me. (I have the pin socket, and didn't care for it). Pyro
November 4, 200520 yr Author i still don't know how to go about replacing them?????thanks Bill I consider the pin wrench socket an extravence and frivolity. A stout brass punch or drift works fine for me. (I have the pin socket, and didn't care for it). Pyro
November 4, 200520 yr If you are using a parts car then just swap the trailing arms. Much easier than trying to swap bearings. They are not generally usable after removing them. Good luck!
November 5, 200520 yr Author If you are using a parts car then just swap the trailing arms. Much easier than trying to swap bearings. They are not generally usable after removing them. Good luck! thank you,i will give that a try.Bill
