November 8, 200520 yr The parking brake on my 1998 Legacy Outback doesn't work. How do I troubleshoot this? If anybody has pictures to go with their explanation, that would help a lot. Thanks.
November 8, 200520 yr The parking brake on my 1998 Legacy Outback doesn't work. How do I troubleshoot this? If anybody has pictures to go with their explanation, that would help a lot. Thanks. the cover around the handle will come off,there is a adjustment under the handle,if this is ok look at cable,pads.
November 8, 200520 yr the cover around the handle will come off,there is a adjustment under the handle,if this is ok look at cable,pads.i should have mentioned that on 4 wheel discs,the parking brake is actually shoes inside of the rear rotor,these are adjustable at the wheel also.
