Rear LSD - keep it simple this time.
if yours is not turbo you have a 3.9.
the existing driveshaft and diff will work
to use an lsd you will have to swap the 3.9 ring gear to the lsd carrier
you will need the e-10 socket for the axle studs
It was optional on the '88 to '90 GL turbos; it was standard on the RXs; in both cases it was a 3.700 which needs to be converted to 3.900. Check with qman or Dr. RX for that if you find one.
What car does the original LSD come from?
