October 1, 200322 yr ok the first line is 0 Rpms so whats the line after that? and the last line before 1,000 rpms?
October 1, 200322 yr Depends on how many lines there are in between . If there's like 4, each line would be another 200rpm. If there's say 9, each would be another 100rpm.
October 1, 200322 yr Author Counting from 1,000 down to 0 their are 2 lines I don't think you count 0 as a line.
October 1, 200322 yr Counting Backwards from 1000 it's 750, 500 then the bottom line is 0. In this pic it is sitting at 0. the next space in the white band is actually 500. The you see the mark for 1 meaning 1000 rpm http://www.rallyracers.com/brat/odo.html Keith
