lytnin88 Posted November 19, 2005 Share Posted November 19, 2005 I'm new to the group, from San Diego, CA. A couple of dumb questions: 1. The rear differential drain & fill plugs need a square tool of about 14mm. Where can I buy such a tool? 2. For the front diff (I have auto trans), I found the dipstick, but is there a drain plug? Or does it never need to be drained? Quote Link to comment Share on other sites More sharing options...
Smpol19 Posted November 19, 2005 Share Posted November 19, 2005 1. The rear differential drain & fill plugs need a square tool of about 14mm. Where can I buy such a tool? I usualy just use a half inch drive ratchet or Impact wrench for taking it off. It will probably be pretty hard to get off if its been on there for a while. I belive the recomended intervel is 60,000 miles. 2. For the front diff (I have auto trans), I found the dipstick, but is there a drain plug? Or does it never need to be drained? Not sure what care you have, but there is a drain plug. In some its off to the side of the dif. On some of the newer ones I've heard they use a torx bolt though I haven't seen those myself. Quote Link to comment Share on other sites More sharing options...
