Hydraulic Lifter Knocking!!!
So i've had this car for over 4 years now.. and ever since i've had it one of the lifters has knocked, and it's finally starting to piss me off!! i know alot of subarus do this.. but how do you go about fixing it....
I'm sure there's other threads about the exact same thing, i just couldn't find them.
find out what side the noise is coming from,pull the valve cover off and check to see if anything's loose.you need to manually crank the engine over so as to run the valves through full cycle.check every 1/4 turn or so.
you'll need a feeler guage too.checking the clearence between rocker and valve.not sure of what the clearence numbers are though.
They are not hydraulic. They are adjustable rockers on a 97
SEA#3
just the lifters are,right??
