Transmission swap
Depends on the year of your car, and what 5spd you are going too. But as a basic list of stuff: You will need the tranny (of course) pedal assembly, clutch cable, shifter assembly, flywheel, clutch disk, clutch cover (pressure plate), possibly throw-out bearing, depending on if there is one in the tranny, rear driveline (specially if your an EA81). As well as the matching rear diff ratio (unless you use a 3.70 ratio trans). Could be other things in there, but can't come up with those without knowing the details listed at the top.
Yeah, the dual range is distinguished by the shift lever. The pushbutton is 4hi only.
Okay I see now. Will any of the trans work?(Selective 4WD d/r, Full-time d/r, or the push button) And what will i need to do it?
I would have to get the parts off of here because no junkyards around here have any subarus.
