Transmission swap
Can anyone give me a list of parts to swap a automatic transmission out for a
5 Speed transmission? And any tips for doing it.
Depends on the year of your car, and what 5spd you are going too. But as a basic list of stuff: You will need the tranny (of course) pedal assembly, clutch cable, shifter assembly, flywheel, clutch disk, clutch cover (pressure plate), possibly throw-out bearing, depending on if there is one in the tranny, rear driveline (specially if your an EA81). As well as the matching rear diff ratio (unless you use a 3.70 ratio trans). Could be other things in there, but can't come up with those without knowing the details listed at the top.
Forgot to put some stuff:
1989 GL-10 AWD Turbo Wagon
I want a 5 speed d/r with the push button 4WD.
Yeah, the dual range is distinguished by the shift lever. The pushbutton is 4hi only.
Okay I see now. Will any of the trans work?(Selective 4WD d/r, Full-time d/r, or the push button) And what will i need to do it?
I would have to get the parts off of here because no junkyards around here have any subarus.
