91 Legacy tires?
I'm picking up a Legacy from a friend that needs tires. Theres 1705/70/14 on there now. I know 185/70/14 where optional. I was hoping to get something a bit wider 185/60/14 maybe. I wasnt sure if I would get rub. Any info would help. Thanks
use this miata.net tire size calculator to figure out what is about the same diameter. 185s will fit without problems, but a 185/60 is a little short. I would say go with 185/70s or 195/65s.
I have 205/55-16s on my 93 Legacy, which are wider and slightly taller, and there is no rubbing. I could fit 215s easily and possibly a 225 if I had the right offset wheels.
