rallynutdon Posted December 1, 2005 Share Posted December 1, 2005 Has anyone ever tried to move their car after one of the front CV joints let go? Will you still be able to drive it? How long did it last after it started clicking with the wheel turned only a slight bit? TIA. Link to comment Share on other sites More sharing options...
nipper Posted December 1, 2005 Share Posted December 1, 2005 a slight but and it clicks? sounds like your past "going" bad and well into "is" bad. Depends if it is awd or manaul 4wd. manual 4wd will get you to the garage. AWD may get you to the shop, but you have to stay below 50mph. with a broken cv joint at 50 the awd in the automtic does weird things, all not good for the car. the awd dissconnects at this speed to protect itself as the spee differnce between the front and rear is too extreeme for it to deal with. This was shown by someone else who drive miles with this, and thats what he had happen. If its a manual with awd, i would think it wouldnt be too healthy for tthe viscous coupling. Also there is the chance of the axle seizing in the cv coint then ALL sorts of fun starts. nipper Link to comment Share on other sites More sharing options...
rallynutdon Posted December 1, 2005 Author Share Posted December 1, 2005 It's a manual. And I know what some of the pitfalls can be. But the car is going to the crusher in 4 weeks (actuallly not going in 4 weeks, but stop driving in 4 weeks, then being stripped before the crusher) and I want to get every last bit of mileage out of it. As long as I can gamble on sensibly limping it home 12 miles maximum if it goes, or atleast being able to drive it on the trailer, I'm going to push it to the end just to see what happens Link to comment Share on other sites More sharing options...
nipper Posted December 1, 2005 Share Posted December 1, 2005 hehe then drive it into the ground ... just dont drive so far that you can get stranded, and if you feel any weird feedback through the steeringwheel, pull over and retire the car. Could mean the cv joint is starting to seize. nipper Link to comment Share on other sites More sharing options...
rallynutdon Posted December 2, 2005 Author Share Posted December 2, 2005 Yea, it's only got 200,000 on the drive train and 260,000 on the chassis. But it was hit last year and it's time to retire the old beast! The good body parts will be available after the first of the year, cheap, real cheap. Link to comment Share on other sites More sharing options...
