rideabmx Posted December 5, 2005 Share Posted December 5, 2005 I have a 97 Outback with over 190k miles. My VSS stopped working and I am also having weird intermittent loss of power/almost stalling issues when I slow down/stop sometimes. More on that problem of mine here: http://www.ultimatesubaru.org/forum/showthread.php?t=42826 At any rate, I've driven the thing into the ground (lots of high speed logging road antics with 4-5 people in the car) and I'm surprised it's still shifting at all (which it does quite well, actually). At my mileage, the thing will probably die soon anyway, and it MIGHT fix this weird stalling issue I'm having, so what the hell? I was wondering, then, what else I should look into replacing/fixing if I'm swapping out my transmission. I know I have an exhaust leak I can fix (since the exhaust system has to be removed). I was also thinking about doing the oxygen sensors since they might not have ever been done, and they might be causing my weird stalling problem as well. Is there anything else I should think about replacing? Thanks, Josh Eugene, OR Quote Link to comment Share on other sites More sharing options...
lmdew Posted December 6, 2005 Share Posted December 6, 2005 I'd do the rear seal and replace the plastic air/oil seperator plate with a metal one if the plastic one is on your engine. Take a look at the mounts and flush the trans fluid. Quote Link to comment Share on other sites More sharing options...
