December 8, 200520 yr Ok I have got everything off the headliner and it still wont come down. I took off all the trim pieces, the map and dome lights, the rearview mirror, and the passenger "OH $hit" handles. What else am I missing, Why wont my headliner come out, How does it defy gravity?????
December 8, 200520 yr hmm...maybe there is some clips up there, kinda like dash clips. I dunno, I've never even seen a sube sun roof
December 8, 200520 yr You have to remove the bead molding around the edge of the sun roof opening . If you look closely there should be a section that the ends meet , grab one end and pull. Also there may be 2 clips by the back window/rear door Hope this helps SEA#3
December 8, 200520 yr Author You have to remove the bead molding around the edge of the sun roof opening . If you look closely there should be a section that the ends meet , grab one end and pull. SEA#3 What? Do you mean the trim like piece surrounding the sunroof? I've tried to pull this down/out but it doesn't want to go.
