Help! Headliner Removal?!?!
Ok I have got everything off the headliner and it still wont come down. I took off all the trim pieces, the map and dome lights, the rearview mirror, and the passenger "OH $hit" handles. What else am I missing, Why wont my headliner come out, How does it defy gravity?????
it should just fall down. Do you have the sun visors out?
yes both of them. It seems to be stuck around the sunroof:banghead:
hmm...maybe there is some clips up there, kinda like dash clips. I dunno, I've never even seen a sube sun roof
You have to remove the bead molding around the edge of the sun roof opening . If you look closely there should be a section that the ends meet , grab one end and pull.
Also there may be 2 clips by the back window/rear door
Hope this helps
SEA#3
You have to remove the bead molding around the edge of the sun roof opening . If you look closely there should be a section that the ends meet , grab one end and pull. SEA#3
What? Do you mean the trim like piece surrounding the sunroof? I've tried to pull this down/out but it doesn't want to go.
