October 4, 200322 yr hello everyone, i'm new here. i have a 1993 subaru impreza 4dr. right now the car has all these ailments, won't start, no headlights, windows won't roll down. things ive done and checked. 1. battery teste good with a load tester, voltage is at 13+-1 2. starter is getting voltage to the two big nuts. 3. checked all fuses to include inside and outside boxes (2 total boxes) all good visual and multimeter 4. checked continuity on three relays located inside above fuse box all good iaw the diagram 5. rebuilt starter, might have carbon build up but everything is clean 6. all fluid levels are good. please help, this car is an overall great car, it's been very realible on long trips, and i have no intension of getting rid of it. no mods, just plain stock. as soon as i paid for the 944t i'll be modding this one tia :banghead:
October 4, 200322 yr Author another ailment found; disconnected the battery (negative) for 'bout 30 min. reconnected, all dash lights worked but upon turning the ignition on all the lights went out, tried again to start it but light won't come on. please help tia
October 4, 200322 yr You may have more luck with the new generation forum because they know more about the new fangled impreza's up there, My best guess would be the ignition switch, there may be somthing internal that is cutting out when you turn the key, try the parking lights, those are independent of the ignition source, if those still work i would go from there.
October 4, 200322 yr It sounds like you have a bad power connection somewhere possibly near the battery area. First thing you should do is remove and clean the battery connections, even if they look ok. If that doesn't fix the problem then look for a connection problem on the smaller positive wire that feeds the cars fuse panel and check the fuselinks. If that checks out ok then I would suspect a power relay problem.
October 4, 200322 yr Author thanks, i found that the ignition switch was at fault. the switch was coming out of the case, so i pushed it in and reclamped the indents to hold it in. thanks you.
