December 14, 200520 yr Hey guys, 94 legacy with 250k. good price but lady says the Manual tranny is making growling noises and will not stay in 4th gear. Are these trannys straightforward to work on, and if not how much for a replacement from like a salvage yard? Also it's awd so this means it has a viscous coupling correct?? Thanks guys. Ryan
December 14, 200520 yr Author Definitely. Just trying to see where I can get a transmission for it and do the labor myself. Any ideas...
December 14, 200520 yr If you can't find one in a local salvage yard, try superrupair online. A manual tranny should't be too expensive, or too hard to replace. Grinding sounds like a tranny gear problem -- not the viscous coupling which I believe is inside the tranny too.
