Dual Sway Bar
Hey subaru freaks
Has anyone heard of or tryed to mount 2 sway bars one directly on top of the other. I saw this i a book and said that you can do this instead of trying to find an aftermarket one or having one custom fabed. I would imagine that it would be tighter then a aftermarket SB, also if you wanted to remove one to loosen the roll you could. Sound cool, I hear an experiment coming.:brow:
I don't see why it woulden't work. you could even try to rig a bowflex type system to fine tune the stiffness.
There are already makers of adjustable sway bars, depending on which hole you put the end link in it makes it "stiffer" May be worth looking into, probably easier than connecting 2 sway bars together.
that would be cool. for EA82 platform cars, there are 17, 18, 19, and 20mm front sway bars, and no 17 for the back. Lots of combinations available! Hope you can weld ;)
