tcspeer Posted January 3, 2006 Share Posted January 3, 2006 Does anyone know of an easy way to get the c-clip off of the Emg. brake bracket that is connected to the rear shoe. I manage to get it off but they must be an easier way. Maybe, I squeeze it to tight when I put the new one on. Link to comment Share on other sites More sharing options...
970subaru Posted January 3, 2006 Share Posted January 3, 2006 do you have the C clip pliers? if so, maybe they suck as bad as mine did.bend the tips in very slightly so they wont want to just slide out of the c clip when you compress it. good luck, C clips are the devil. Link to comment Share on other sites More sharing options...
tcspeer Posted January 4, 2006 Author Share Posted January 4, 2006 Are you talking about the ones that you can change the ends and make them do different things, I have a pair of them but they wont get a good bite. I think they came from Harbor Freight so maybe I need to get a good pair from Snap On or Sears. do you have the C clip pliers? if so, maybe they suck as bad as mine did.bend the tips in very slightly so they wont want to just slide out of the c clip when you compress it.good luck, C clips are the devil. Link to comment Share on other sites More sharing options...
