Temp gauge gone wild. Need clue. Please help.
'96 Outback. Larger engine (2.5L?)
My temperature gauge fluctuates from medium to full hot and back down again while the engine shows no other signs of trouble: No steam boiling out, coolant level is normal, engine seems to operate normally. I suspect the sending unit has lost its mind. Where is it? How can I test it? Should I test the Gauge also?
Maybe I should measure the actual operating temp of the engine. What should it be?
Thanks,
Paul
my guess would be either a sticky thermastat or a air pocket in the cooling system.
OBD2 scanner will show engine coolant temp independently from your tem gauge. It should be 180-212 or so.
Check it out before driving more as you might be overheating the engine.
