pattiandruss Posted January 9, 2006 Share Posted January 9, 2006 I changed the O2 sensor on my wife's 93 Legacy today, it had a constant check engine light, and a 32 code. But, I used a Bosch universal sensor, 3 wires, and I hooked it up wrong. The instructions were vague, and I hooked the sensor lead to a heater lead. So, probably put 12 volts into the sensor port of the ecu. It will start just fine, but dies very soon. If I keep it above 2000, it will run OK. It was running fine until I did the sensor change today. Pretty sure I didn't knock anything loose or do any other damage under the hood. Tried unhooking the o2 sensor, then put the old one back on, but no luck. Help!!! Russell Quote Link to comment Share on other sites More sharing options...
PAezb Posted January 9, 2006 Share Posted January 9, 2006 I changed the O2 sensor on my wife's 93 Legacy today, it had a constant check engine light, and a 32 code. But, I used a Bosch universal sensor, 3 wires, and I hooked it up wrong. The instructions were vague, and I hooked the sensor lead to a heater lead. So, probably put 12 volts into the sensor port of the ecu. It will start just fine, but dies very soon. If I keep it above 2000, it will run OK. It was running fine until I did the sensor change today. Pretty sure I didn't knock anything loose or do any other damage under the hood. Tried unhooking the o2 sensor, then put the old one back on, but no luck. Help!!! Russell After reinstalling the old O2, did you reset the ECU by disconnecting the battery for a few minutes? Quote Link to comment Share on other sites More sharing options...
pattiandruss Posted January 9, 2006 Author Share Posted January 9, 2006 Yes, I did that. Quote Link to comment Share on other sites More sharing options...
pattiandruss Posted January 9, 2006 Author Share Posted January 9, 2006 Should the car run with the o2 sensor disconnected? Russell Quote Link to comment Share on other sites More sharing options...
Andyjo Posted January 9, 2006 Share Posted January 9, 2006 how much are those universal sensors anyhow.. i have no clue how to fix the problem, but i need to change mine soon Quote Link to comment Share on other sites More sharing options...
tcspeer Posted January 9, 2006 Share Posted January 9, 2006 If you was under the hood check and see if the big hose is off from the thing that hooks the air filter to the big black thing at the back of engine. It is about 3/4 in. hose and is on the bottom of air filter duct. When that is off it causes the engine to run like you say. Quote Link to comment Share on other sites More sharing options...
pattiandruss Posted January 9, 2006 Author Share Posted January 9, 2006 The sensor was $44 from Shucks Auto, but you have to print out the price from Parts America, their on line outlet to get it that cheap. Otherwise was $65. I found my problem, by the way. Knocked off a large vacuum hose under the main air intake, now it runs fine. Just have to rechange the O2 sensor, but I know how now. Russell Quote Link to comment Share on other sites More sharing options...
pattiandruss Posted January 9, 2006 Author Share Posted January 9, 2006 Boy are you ever right. That's exactly what it was. Thanks, russell Quote Link to comment Share on other sites More sharing options...
cookie Posted January 9, 2006 Share Posted January 9, 2006 It would be my guess you are about the 700th person to do that. We all learn that one the hard way. Quote Link to comment Share on other sites More sharing options...
