Replacing Coolant 97 Legacy
I posted here that I replaced my engine temp sensor on my 97 Legacy OBW a couple of days ago. In the process I lost about .5 gal of coolant. I added back while running the engine and will check before I go out the next couple of times.
I started thinking, and worrying, and as I am deathly afraid of doing a HG replcement (did one on my last car, also prone to Blown HG:banghead: ) Ill ask...
When replacing such a small amount should I worry about additives, type of coolant, special need to burp or remove air, etc ?
I used a premix 50/50 Prestone I believe.
TIA
Hentai
As long as the temp gauge is reading the same, you did not get air into the system. Most coolants are OK to mix.
Fresh coolant and a good flush is always a good thing.
