January 17, 200620 yr when you put your 5 spd d/r in ,did you experience what felt like bind in the front end?it only happens when i am going around corners. did i maybe happen upon a fulltime?my axles fit....? whattup???
January 18, 200620 yr this happened to me when i first put a D/R in my auto car. i thought i had the wrong gear ratio diff. so i got a different rear diff. it was then worse. i just drve the crap out of it. (trans was under warrenty) and it was all good. trans had been sitting for years. maybe something just needed to be loosened up. this was 4 years ago, havent had any prob since. -=Suberdave=- http://www.suberdave.com
January 18, 200620 yr Author it just may be the different feel.but man it feels like it is binding.weird.i'll let it go for a day or so and see how it feels.
January 18, 200620 yr let me drive it and watch the tires as you drive it. it might just be the size of the tires. Might get better when you put in the LSD (more push from the back? or would that be only with a FT4wd?)...
January 18, 200620 yr Author that would be ft4wd........it might be a ft4wd.it.s from a 90's loyale.and i don't think it was original
January 18, 200620 yr Hmmm.. Can you not tell FT4WD from P/T 4WD by the linkage? That and the FT did not have much reduction in Low.
January 19, 200620 yr with the FT, you'll notice the 4wd linkage has 3 positions where the part time has 4. Full Time d/r 4hi neutral 4low Part time 2hi 4hi neutral 4low You'll notice a major difference...
January 19, 200620 yr Author i guess that my linkage tweaked when i mounted it......it has been moved now.and the 4wd lever goes all the way down .i have to say that i have been under some stress and i guess i was trying to rush it.it is my daily driver ya'know. i am the king........ on a positive note....i can do 65 in 4 hi.
January 19, 200620 yr Author nope ,no bind.it still is really grabby.i went to the rgavel pit after work and it seems that i need a witness to check me out from the exterior of the vehicle .i'll get ruda to check it out this weekend.
