January 22, 200620 yr does anyone know if there is a fuse for reverse lights i lost my fuse cover panel and don't have an owners manual. needless to say i don't have any reverse lights. any other ideas other than fuses and bulbs
January 22, 200620 yr No I don't believe there is a separate fuse, however it is tied into one of the fuse blocks. Do you notice any thing else that isn't working? Here's a diagram for the first gen legacies http://www.surrealmirage.com/subaru/files/swap/6-3_back-up_light.jpg BTW, what year and model subie do you have?
January 23, 200620 yr If it is a Forester 98-02, it would be Fuse 18. It also controls: AT shift lock control module Back-up light switch (MT) Cruise control main switch Cruise control module Daytime running light control module Daytime running light relay Hi-beam relay Inhibitor switch (AT) Keyless entry control module Security control module Wiper deicer relay Wiper deicer timer So of you have a 5 Speed L model, without cruise and without DRL (high beam relay in only on Forester with DRL), you might not notice anything else wrong.
January 23, 200620 yr If the connection to the light is ok and the bulbs are good then I would check the switch next. They are usually mounted in the transmission case.
