January 23, 200620 yr Step one: Remove the lower engine to transaxle bolt on the drivers side. The one you should wear a heavy leather glove to save your knuckles. IF you can break this 14mm (across the flats) nut loose, it's all downhill from there! Wheres my salve. OUCH!
January 23, 200620 yr Sounds like you have made the blood sacrifice to the mechanical Gods. They will be pleased. nipper
