January 28, 200620 yr Well I got my LSD...so now I'm going to rebuild the whole rear diff case (it's leaking out of all the seals). Anyone have a blow up diagram of it? A list of the seals on it would work also (obviously there are 3...pinion shaft and axle shafts...any others?) Does the pinion shaft bearing wear out commonly? It's cheap to replace while I'm in there anyway (I'd like to order one before I have the thing apart if it's something that is commonly worn).
January 28, 200620 yr Hey. Its good to know you got that thing all right. You are swapping from open to limited slip right? If so here is the link to the rebuild: http://www.ultimatesubaru.org/forum/showthread.php?t=49919 There's also another thread around her that I'll post up in here that has a diagram. Good luck with the rebuild. EDIT: Here ya go with that second thread: http://www.ultimatesubaru.org/forum/showthread.php?t=30872
January 28, 200620 yr i wanna know if you can get replacement clutches for when the LSD's wear out... ~Josh~
January 28, 200620 yr Author Anyone ever order some of the Nissan/Datsun R160 clutches? Part numbers are available at the bottom of this page: http://www.gordon-glasgow.org/lsdtech.html
